Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Drawing: Add individual columns to revision table
1 REPLY 1
m.neujahr_at_moe
115 Views, 1 Reply
Hello devs,
is there any possibilty to add individual columns to the revision-table in drawings?
Would be nice to add features like BOM-Date, SW-Version, ..
And to change revision numbering from chars ("A") to numbers ("01")
Thank you for your efforts
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
1 REPLY 1
Hi @m.neujahr_at_moe
I was able to pass along the suggestion to the drawings team. It's currently not possible to add the columns but in the mean time you could use a custom numbering scheme to achieve the revision numbers that they are looking for (set up under document settings). A custom numbering scheme is different to alpha or numeric scheme, in that it is not pre-populated. At the time of creation, you need to specify the revision.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
