Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Don't understand how to edit a local library.
3 REPLIES 3
Le_Bear
221 Views, 3 Replies
Ok as an exemple, I have this library LED, which is local
Once I open it to edit, I get that warning in blue "Library is opened in read-only mode. Chose File-> Save AS ... to save changes to this document". OK, So, when I go to File, "Save as" is grayed out.... Catch 22 kind of thing.2021-02-21 17_14_37-Window.png
So, what am I supposed to do ? Is there another way ?
Thanks for your help.
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
3 REPLIES 3
PinRudolf
in reply to: Le_Bear
I think clicking Save instead of Save As will perform the same at this point. It recognises the library as an unsaved document. Does that work for you?
Le_Bear
I need to test. I am in something totally different now. I'll get back to you once I have been able to test.
Bernard Grosperrin
Hi @Le_Bear ,
Thank you very much for asking and so sorry for any confusion.
Thank @PinRudolf for your replying, and you are correct that in this case need to click Save button instead but not Save as.... (I will log a ticket to our development to check).
When you edit a local library (which provided by Fusion 360) from Library Manager, need to click Save button to save it to your Fusion data panel (Fusion team), and then you could edit your own saved library further.
Hope it helps.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
