Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Dimensions between electronic components
1 REPLY 1
lerxstjunk
103 Views, 1 Reply
Trying to figure out if there is a way to put dimensions between components. For example lets say I have five switches and I want them to all be exactly 30 mm apart. Then if I need to move one of the switches all the other switches would move and stay 30mm apart.  I can easily do this in a sketch in the CAD Design area but I can't find any way to do this in the PCB layout.
1 REPLY 1
panpan_fan
in reply to: lerxstjunk
Hi @lerxstjunk
I hope you are doing well!
As I know, we can't support keeping dimension when move components.
As a workaround, I would suggest that you can use the Arrange command to arrange components easily.
You can just do it once when you have confirm the first position.
Please have a try, thanks!
For your request, I will report it to the develop team to see if we can do some improvement in the future.
Panpan Fan
