Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
DIFFICULT SEEING A TRACE ON BOTTOM LAYER WHILE ROUTING
4 REPLIES 4
RCBakerBorn
129 Views, 4 Replies
WHEN I LAY A TRACE ON THE TOP LAYER OF A PCB, THE OUTLINE OF THE TRACE IS BLUE TO HELP WITH THE VISUAL WHEN ROUTING THE TRACE.
HOWEVER, WHEN LAYING A TRACE ON THE BOTTOM LAYER, THERE IS NO OUTLINE. EVERYTHING STAYS BLUE SO IT IS IMPOSSIBLE TO PHYSICALLY SEE THE TRACE AS I TRY TO ROUTE.
I AM WORKING WITH A FOUR LAYER PCB DESIGN.
IN A 2-LAYER PCB DESIGN, USING EAGLE, I DID NOT EXPERIENCE THIS ISSUE.
4 REPLIES 4
Have you tried turning off the layers that you are not using? When routing, I usually turn off as much as possible and just leave dimension, unrouted, pads, vias, and maybe a few other on. It helps me to get rid of the distractions.
I WILL TRY THIS. THANK YOU FOR THE QUICK RESPONSE.
THIS WORKED.
I'VE ACCEPTED THE SOLUTION BUT A "WOULD BE NICE" FEATURE WOULD BE TO AUTOMATE THIS IN THE FUTURE.
THANK YOU!
jorge_garcia2
in reply to: RCBakerBorn
Hi @RCBakerBorn,
I hope you're doing well. The weird thing is that routing on the top gets you a blue color. Could you post an image of what you are seeing?
In addition to what @michael.walach72K5A mentioned, if you have any polygons filled in hide them. That will make routing much easier.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
