I started a new electronics-library with Fusion360. I made some symbols, footprints and one new device.
Because I wanted to use this library in an older Eagle-design I exported this library with Fusion 360:
The first time I used the second item (EAGLE-Bibliotheksdateien) and had some trouble with the import in Eagle:
- I saw all the item-names in the Library-Editor, but I can't see anything to edit:
So I tried the export with the third item (Mit EEAGLE 9.X-Bibliothek ..) and now it works:
Can you please give an explanation how to use export the right way. What's the difference between the two export variants?
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
