Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
device, symbol, footpring, 3D disconnect
2 REPLIES 2
wwfeldman
204 Views, 2 Replies
another in a long list of frustrated users
since AutoDesk will eventually discontinue stand along eagle, and to facilitate electrical and mechanical working together, i have started learning F360 and using the eagle portion, instead of stand alone eagle
in eagle (at work):
i created a managed library and put in components (devices, symbols, footprints and 3Ds) for things in the current project.  using the library table of contents, i checked each device - the symbol, footprint and 3D showed up, as expected and looking correct, in the "show boxes" on the right
in F 360 (at home)
i downloaded F360 onto my home computer
i  signed in and opened the same managed library
i created a schematic with one or two of each of the components made in eagle
i created a PWB and then a 3D version - very pretty and reasonably easy
the schematic and PWB looked ok
the 3D however was not ok
3D footprint SOT95P285X113-3N (SOT23 with 3 pins) is used on 4 different devices
(an NPN transistor, a PNP transistor, and two different 3 terminal regulators)
half of the packages in the 3D were correct and the other half were just grey boxes
in addition, three ICs, (an instrumentation amp, an op amp, and a comparator) that use the same footprint and 3D (soic-8) were not ok - two have the component rotated 180 degrees from were it should be (pin 1 at pin 5 location), and the third is a grey box
two other ICs, in different packages, are ok
F360 (work)
i opened the files on my work computer that i had created at home
same issues - except here, there appears to be no library table of contents to check the annotations between device, symbol, footprint and 3D. when i went through the list of devices in the managed library, all look well - correct symbol, footprint and 3D
F360 side issue:
there are 4 tabs - schematic, PWB, 3D and a tab showing 4 drawings: schematic, PWB, 3D front and 3D back - they have the same name, but different revisions (which makes sense) but the symbols that distinguish them are odd and i would prefer it just said schematic, PWB, 3D and (??) instead
also, i would prefer they show up in the data panel as one item instead of 4
F360 second side issue
when i open library manager, my managed library show up twice:
(correct name),    team         ,    version 8,   a chain  v19,   the managed folder,  description
(correct name),    library.io  ,    version 1,     blank          ,   the managed folder,  description
please explainer why there are two of what looks like the same library
Labels (3)
2 REPLIES 2
jorge_garcia2
in reply to: wwfeldman
Hi @wwfeldman,
I hope you're doing well. There is a lot to unpack here but one thing that can sometimes happen when working in two different locations. What can happen is that the cache list in Fusion360 doesn't update to the latest version correctly.
To make sure that is not what's going on click on the question mark on the upper right and select support and troubleshooting, in that menu you'll find an option that says clear cache. That might help with the main issue. Thank you for your feedback on the side issue.
In regards to your second issue, they may have the same name but from the description I have a feeling they may not be the same library. By any chance, is it possible you made a second library by accident in on the EAGLE side?
Double check but I have a feeling that they have different URNs which would mean they are different libraries.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
wwfeldman
in reply to: jorge_garcia2
what is the difference between team and library.io?
i used windows explorer to find the libraries under
C:\Users\Larry\AppData\Local\Autodesk\Autodesk Fusion 360\Electron\lbr
there are three folders:
adsk.eagle_library_22273412
adsk.eagle_library_22274948
adsk.eagle_library_22275315
each has one library, (name).lbr , where the name is the library name
the libraries with the same "name"
22275315 is 102 kB,  while 22274948 is 16 kB
i assume(?) that the small size is the "extra"
how do i remove it, as it resides on my PC and in the cloud?
