Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Device name filter, for multiple devices names
4 REPLIES 4
alexandre.palardy
113 Views, 4 Replies
Hello
I would like to select multiple device by entering a name list.
Exemple:
I would like to select C1,C11,C12,C14
In de device manager I can't searches for more than one name:
What I would like to do is :
I know that I can create a different line for each Name, but it is not useful. I would like to copy past the list of name from the BOM.
In fact the main problem is that I can't search for a specific attribute value. For each device in my design, I have an attribute for my inventory part number.  Ex: Attribute name is INV and value is R100K0603. I would like to select in my design all the part that have the attribute  INV= R100K0603. So, the idea to select multiple name like C1,C2,c12 is to find a turn around to this problem. I will make a filter in my BOM file so when I select R100K0603 it will give to me the list of device name that have this inventory number.  Then select all those components in my design.
Thank you for any help
Alexandre
4 REPLIES 4
Hi @alexandre.palardy
I hope you are doing well!
For your question, you can try (Name = C*)
Please check if it works for you.
Panpan Fan
@panpan_fan
(Name = C*) will select every C* named device. So it does not work for me.
Thank you for the response.
Alex
Hi @alexandre.palardy,
I hope you're doing well. For your particular situation you can use C1* and then filter down further from there. You are right that being able to filter based on attribute value would be boss. I'll add report this as a feature request.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hi @jorge_garcia2
Thank you for the response. Yes it will be VERY useful to filter based on attribute value.
"I'll add report this as a feature request." this is nice. Thank you
Alexandre
