Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Destroyed Eagle Library in Fusion 360
1 REPLY 1
j.kollmitz
160 Views, 1 Reply
well, almost...
I'm trying out Fusion Electronics and I'm reusing my managed library from Eagle. After adding some new parts in Fusion and updating the library, I couldn't add any devices anymore. When I opened the library it showed "no devices". Strangely, on library.io the library still showed all devices (even the ones I added in Fusion). I checked the version and they matched.
It took me quite a while to fix it: Opening the latest version of the library in Eagle gave me some error messages about the library XML file. Apparently, I had named one pin in a new part "", but Fusion didn't give me any warning. I could manually fix the XML file (in Eagle's local cache) and create a new library version in Eagle.
Fortunately everything is back to normal but I'd defintely expect a warning from Fusion before (almost) destroying a library. Please fix 😉
Best,
Jan
1 REPLY 1
j.kollmitz
in reply to: j.kollmitz
Actually, fixing the XML didn't just do the trick. It just allowed me to open the library in Eagle and I thought that was it.
But after uploading a new library version it still didn't work. But I could open the part in Eagle and change the pin name again (after already changing it in the XML) so Eagle acutally recognized the change. Pushing a new version again finally did it.
