Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Design a case for my arduino project
2 REPLIES 2
410 Views, 2 Replies
i am new to Autodesk. I have put together a physical circuitry using stripboard and arduino nano. I would like to create a snapped case to hold the board and a 9v battery that drives the circuit.
I tried to create components in fusion 360 and eagle and ran into some problems. Hope someone has a similar experience and give me a clear step-by-step tutorial to follow.
First step I tried is to create a component of the board — I downloaded a arduino nano .f3d file from the web. I then create a rectangular circular board with the actual size of my stripboard. I tried to put the arduino nano on the stripboard at the exact location on my actual board. But I don’t quite know how to move and align the arduino nano to the board in fusion 360. When I used the align command, it aligned part of the arduino and did not move the whole arduino nano as a whole. I am
stuck here. Please advise.
regards,
simon Lee
2 REPLIES 2
PW_VOX
After you import the Arduino assembly, Right click on the assembly in the browser and select Rigid Group.
in reply to: PW_VOX
Thank you for your advise. It works.
Simon
