Custom pad not displaying properly in 3D
tgsell
tgsell
Custom pad shapes are not displaying properly on 3D even though manufacturing preview works fine.  The polygon is fully overlapping the pad.  Also the polygon on the tstop layer is not showing up.
Replies (8)
yiqiu.han
Hi, @tgsell
Would you please try to view 3D PCB again with "Stop layer geometry" option checked? By default, we don't check this option for the reason of performance consideration.
Yiqiu
tgsell
It is the same with or without Stop Layer Geometry.
yiqiu.han
Hey. so is it possible;e for you to share the data with us for investigation? (any approaches are welcomed, like direct message or e-mail)
Yiqiu
ilia.vitsnudel
Exactly the same problem. Custom made pads are not shown correctly in 3D model, however shown correctly in CAM preview. I am sending an example of custom pad library and design through e-mail.
Thank you.
panpan_fan
Hi @tgsell
I hope you are doing well!
Thanks for sending your file to us!
For the footprint polygon issue, it is a known issue and has been reported to our develop team.
I will keep you updated when we release the fix for this issue.
Panpan Fan
ilia.vitsnudel
Thank you.
Couple of questions:
- Do you have an ETA for this solution? Is it days, weeks, months?
- Is there any alternative that I can use to make custom shape pad?
Ilia
panpan_fan
Hi @ilia.vitsnudel
Our develop team is working to fix this issue. We will try our best to fix it ASAP.
By the way, you can use the rectangle polygon in the footprint to have a try.
The rectangle polygon should covers the pad completely.
Please have a try, thanks!
Panpan Fan
HelenChen-ElectronicsQA
Hi @tgsell,
Hope all is well.
We have fixed this issue in latest Fusion release with version 2.0.13615.
Could you please upgrade to latest version to have a try?
Hope it helps.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
