Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Custom font doesn't work, can't select custom.
1 REPLY 1
01xDaniel
140 Views, 1 Reply
Hi
I can't edit text to get from vector to custom or to anything else.
I can select custom when adding text but it doesn't appear when placing it.
I'm on a Apple M1 Pro, and I have "enable GPU rendering" turned on.
Fusion 360 2.0.15995 x86_64 [Rosetta 2]
Active Plan: Student
macOS 13.3.1 (22E261) on MacBookPro18,3
1 REPLY 1
Hi @01xDaniel,
Thank you very much for asking.
Could you please check whether the "Always vector font" is checked in your preferences?
If yes, then you are not able to edit the text font in Inspector due to this setting.
Instead, please uncheck that option, and you should be able to edit the text font in Inspector as you wanted.
Hope it helps and hope you have a great day.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
