Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Ctrl-W Closes Schematic
1 REPLY 1
kevin2MSFQ
137 Views, 1 Reply
In an eagle schematic , Ctrl-W initiates the drawing of a wire.
In a fusion schematic , Ctrl-W immediately closes the schematic window and sometimes ruins the schematic/pcb sync.
As an Eagle user for 20 years, I press Ctrl-W frequently.  The new behavior makes me frustrated frequently.
I know that Fusion is not eagle, but you are brining along many of us grey beards along for the journey.
What is ctrl-W intended to do in Fusion?
1 REPLY 1
jorge_garcia2
in reply to: kevin2MSFQ
Hi @kevin2MSFQ ,
I hope you're doing well. In Fusion 360 Ctrl+W is a reserved shortcut for closing the window 😞
I tried to see if I could just reassign it to the net command but Fusion doesn't allow this. I'll put in a request for some way to change this, but it's not likely this will change soon. If it helps the current shortcut for the net command in Fusion 360 is R.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
