Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
CSV (comma-separated values) Output separates things with a semi-colon?
1 REPLY 1
eric_engineer
87 Views, 1 Reply
Come on really? 🙂
1 REPLY 1
Hi @eric_engineer,
I hope you're doing well. Everyone always assumes it's comma-separated values but it's actually character-separated values. In some european countries the semi-colon is preferred to the comma because comma is generally used as the decimal point.
Excel and calc can both handle the semi colon so it shouldn't really be a problem, but if you want the comma you can go into the ULP code and near the top you'll find the delimiter variable you can change it to be a comma there.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
