Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
cross probe placement from schematic to pcb
7 REPLIES 7
Message 1 of 8
eric_engineer
222 Views, 7 Replies
Is there still no feature to click a part in the schematic and have it ready for move and placement in the pcb editor?
7 REPLIES 7
Message 2 of 8
yqliu
in reply to: eric_engineer
@eric_engineer , the following command will do the trick:
run select-sch-group-to-brd-group.ulp
Message 3 of 8
eric_engineer
in reply to: yqliu
That didn't do anything for me.
Message 4 of 8
yqliu
You need to have both schematic and pcb open and then select a part before running the command.
Message 5 of 8
okay after it crashed and I came back in it says "multiple profiles defined. Edit the sketch to create a single profile"
Message 6 of 8
yqliu
This message should be from 3D PCB environment. It's a different problem than cross probing between schematic and 2D PCB. The message means the application cannot detect the outline automatically because there are two closed outline regions.
Message 7 of 8
eric_engineer
in reply to: yqliu
Ah okay. That's what I want to do cross probe from schematic to pcb. It is a much more efficient way to place parts.
Message 8 of 8
I’ll only add that this is currently slated for work next year.  We will get more details and of course it’s subject to change but this is something we prioritized knowing the value of these small but powerful enhancements to workflow. @jd.vorheis
Best regards,
matt - Autodesk
