Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Creating trace antenna from smd pads
2 REPLIES 2
corsmeierkevin
106 Views, 2 Replies
Hello, I was just wondering how this antenna design would play out. I created a symbol for the antenna, and have created the desired dimensions/shape using smd pads for the foot print. I was just wondering how I might ensure that this is covered with soldermask/ treated like a route on the actual board. I deselected the soldermask option when clicking on properties of the footprint for each placed pad when creating the footprint. It looks like there is no longer the grey hatched area signifying that solder mask should be applied over it, however when pushing to a 3d pcb, it appears the pads are above the layer of soldermask. My quesiton, is this something that I can ignore and solder mask will be applied over it and the traces connecting? or is there some method I should be changing the thickness of the pads to match that of the routes to it? New to fusion electronics so any help is greatly appreciated. Attaching pics for reference of layout view and 3d pcb view.
Labels (1)
2 REPLIES 2
Hi @corsmeierkevin,
Excellent question, the 2D PCB is the ultimate source of truth. As long as your antenna doesn't have any features on the TopSoldermask layer they will be covered. The 3D PCB just doesn't reflect the stopmask correctly in this case, it can be safely ignored.
I'll report this anyway since that copper should be covered.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thank you for the quick response. This is good to know!
Best,
Kevin
