Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
creating component footprint of smd inductor CD43
6 REPLIES 6
dm.pozhidaev
493 Views, 6 Replies
Hello
I new in fusion 360 and eaglee too.
I dont found ready for use component and want create it.
the description of inductor is at address
http://www.chipcomponent.com/pd43_smd_power_inductors.html
Can somebody show how create an arc pad or may be show the howto video for near example.
Thank!
6 REPLIES 6
yiqiu.han
in reply to: dm.pozhidaev
Hi, @dm.pozhidaev @dm.pozhidaev
You could go to the File menu> new electronics library, then create symbol, footprint and connect pins of them together in a new device.
You could also create 3D package for footprint via right-click menu on the existing footprint, all 3D design commands are available for 3D package design.
Any other questions please let me now.
-Yiqiu
dm.pozhidaev
in reply to: yiqiu.han
Ok. Thank you very much!
I mean how connect to pad of footprint an arc form connect area.
yiqiu.han
Here are the detail steps:
1. Add symbol
2. Add/import local package
3. Connect pins and pads
Icons are demonstrated in the capture
-Yiqiu
dm.pozhidaev
Very fine answer! Thanks!
How draw an arc form pad at footprint correctly?
Hi @dm.pozhidaev
in order to get the shape of the contacts you could use a SMD inside a polygon. The polygon has the shape of a kind of half-circle. I added a screencast that shows how to do this. I did not take care on precise coordinates, bnut hope it shows you how to do this.
Richard Hammerl
Thanks!
