Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Creating Circles in PCB Electrical Design Problem
2 REPLIES 2
osamaolabi
327 Views, 2 Replies
Hello Everyone,
I'm having a problem with creating circles inside a PCB Electrical Design. After creating my sketch in the design and exporting it as DXF. Importing it into the 2D PCB Design in Fusion results in missing circles.
But when I import the same DXF into Eagle it imports perfectly, and then I have to save it as a .brd and import it into Fusion360.
The problem I noticed within F360 is that when there is an error in the drawing, it just doesn't load the sketch. But in Eagle it still loads the sketch while highlighting that there is an error.
I realized that in F360 PCB Design you can not create a Circle inside a Circle. which is what is causing the problem in my opinion.
Here are the pictures (Sketch, Fusion360 import, Eagle Import) and attached is the DXF for anyone interested in giving this a shot.
Thank you,
Osama
Labels (3)
2 REPLIES 2
jorge_garcia2
in reply to: osamaolabi
Hi @osamaolabi ,
I hope you're doing well. Fusion 360 electronics has the same DXF import ULP that EAGLE uses so you should be able to get the same result. So I recommend using import-dxf ulp in Fusion 360 BUT copy the import script from the ULP when it shows you the preview. Don't just run it because it currently doesn't work correctly. Copying the script will allow you to just paste it into the Fusion 360 Electronics CLI and hit enter to import it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
osamaolabi
in reply to: jorge_garcia2
Hi @jorge_garcia2,
Even using the ULP from Eagle with the same settings doesn't work.
I did find a solution though, Edwin from the Fusion team helped me out when I was on the Fusion Call the other day.
When you are in the 2D PCB Design screen. In the bottom ribbon there is an option to ignore violators. Once you toggle it, everything works like a charm :).
