Creating 3D PCB from pcb does not work!
HouseOfMollari
HouseOfMollari
Since the current patch, neither an existing 3d PCB can be updated nor a new PCB can be created.
When starting the process, Fusion360 completely hangs and nothing happens for hours until killing it via taskmanager.
Replies (28)
jorge_garcia
Hi @HouseOfMollari ,
I hope you're doing well. If Helen already has access to your files then she'll be able to verify performance. Could you provide some information about your design? How many vias? How many components? Etc. There's a performance improvement coming in the next Fusion release that should help alleviate this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
HelenChen-ElectronicsQA
Hi @HouseOfMollari
As @jorge_garcia mentioned that there's a performance improvement coming in the next Fusion release that we think should help alleviate this. We will keep you be posted once the new version is ready for you to double check.
Thank you so much for your feedback.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
jesper8W75R
@Anonymous
How does it go with the weird frame/text bug we discussed in our session?
I'm still not able to generate a PCB due to this.
It affects not only the 3D PCB, but also the CAM processed board.
I need to get that board delivered, so would really like to have it solved.
HouseOfMollari
Are you sure you hit the right thread?
jesper8W75R
Right on it, yes.
panpan_fan
Hi @HouseOfMollari
Today we release Fusion 360 V2.0.10806 and the View 3D PCB performance issue should have been fixed.
Please have a try, thanks a lot!
Panpan Fan
HouseOfMollari
I hope everyone is doing well.
Today I tested the new release of Fusion 360 with my design.
It partially works. Calculating starts, I see messages in that progress bar like Copper Top, Copper Bottom, 3D-Packages. But in the last step where progress bar shows "preparing calculation" the complete process stucks again. It is in that state vor 30minutes now. I think there is another issue you haven´t discovered.
Regards
So sorry about this...
Do you mind to resent your file to me to have a try?
I will send private message to you later.
Thank you.
Helen
Helen Chen
Thank you very much for inviting us into your project, we are able to reproduce this issue you met.
So sorry for any inconvenience, our developer will check this.
We will keep you be posted.
Helen
Helen Chen
