Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Create Multilayer PCB with Custom Outline
0 REPLIES 0
Message 1 of 1
scottpickles
110 Views, 0 Replies
Hello All -
This is my first time posting here and I'm a casual user of Fusion 360, learning mostly via the internet and YouTube videos.  I have a custom shape PCB that was derived from a sketch (it's essentially a custom logo).  I am placing dotstar (APA102) surface mount LEDs on this board.  The LEDs have a requirement for VCC (parallel), GND (parallel), clock input/output (serial between each LED) and a control signal in/out (serial between each LED).  I would like each function to have its own layer, and as far as I can tell I've done that.  I have chosen the top layer for VCC, the bottom layer for GND and the two other layers are for those other signals.  I will route the connections between the LEDs individually using those two layers.  For the VCC and GND layers I'd like to 'pour' polygons on those layers so that all I have to do is create the appropriate vias to those layers to make the connections.  I cannot figure out how to perform the 'pour' function with my custom outline logo PCB.  I see a green outline around the logo PCB which makes me think the polygon is already there and recognized?  I've attached a screenshot of the layer stack manager.  I also tried the auto router feature which got really close, but I don't know how to finish things up after that because it only gets to like 95%.  I chose to run the auto router with all 4 layers as 'auto' as well and I expected route lines on each of the 4 layers but I didn't see that happening.  I'm assuming it will route to the other layers only as necessary when auto routing?  After all of this rambling my asks are these:
1. How do I create the ground plane and VCC plane so I can make those connections with simple short vias?
2. How can I force auto router to make use of the 4 layers I've specified to route the connections?
If auto router can't automatically route the serial connections for the clock and control signals, I can do those manually (that much I have figured out).
***UPDATE***
I was able to pour a ground plane on the top layer.  But the moment I rename it "GND" and link all of the ground points from the schematic, Fusion 360 crashes and quits.
0 REPLIES 0
