Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Create board of exact size
2 REPLIES 2
infinite.machinery
1721 Views, 2 Replies
I need to create a board that is 128.5mm X 30mm. When I do this the actual board dimensions turn out to be slightly larger. I believe this is due to the lines that outline the board having a width.
Do I need to take into account the width of these lines when sizing a board? I don't remember having to do this with Eagle.
2 REPLIES 2
Hi @infinite.machinery
the width of the dimension lines does not influence the final size of the PCB. When creating Gerber data for manufacturing it's always taken the coordinates of the lines. They do not depend on line width. A value for with of about 0.1 or 0.2 mm (4 - 8 mil) is usual.
Hope this helps.
Richard Hammerl
https://forums.autodesk.com/t5/fusion-360-electronics/board-size-which-one/td-p/9327226
It is 1 mm for me. But I assume from your answer that the larger value is correct. Will this be taken into account when I create an enclosure as described in https://www.youtube.com/watch?v=8Ny4kWdhTbg
