Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Correct way to model a thermal load
1 REPLY 1
xgabry95
91 Views, 1 Reply
I have a doubt about the correct way to implement a thermal load. I have an electronic unit that has an internal generation of X watts. The unit is attached to a metallic plate; what I know is that the unit transfers 0.5 [W] to the metallic plate. I imposed this condition by introducing an Heat Source load at the surface in contact with the metallic plate and assigning -0.5[W]. I choose the negative number to indicate that the thermal flow is exiting the electronic unit. Can someone confirm that this is the correct way to model such a situation?
Thank you
Labels (1)
1 REPLY 1
jorge_garcia2
in reply to: xgabry95
Hi @xgabry95 ,
I hope you're doing well. I would recommend using the E-cooling simulation in the Simulation environment. It sounds like you might be using CFD? In the E-cooling simulation you can assign heat loads to components in your design. You would enter the load as a positive number, the tool knows how to process it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
