Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Copying existing circuitry into a derived PCB
2 REPLIES 2
jeremiahrose
450 Views, 2 Replies
Hi there,
I have been testing the new "Derive PCB from sketch" feature and it is great to see a new empty PCB be created, and receive update notifications when the original sketch is changed. It even seems to work for a sketch that is not in the XY plane, so that's awesome to see the PCB integration getting closer to usability!
I would like to start a new project with this workflow, however I need to reuse a significant amount of circuitry from a previous project and I am having difficulty in copying parts of the old board layout into my new project.
Here's the process I tried:
  1. Create a new Fusion file called "Case", design my casing, draw a sketch in the XZ plane, save the file, then choose "Derive PCB from sketch".
  2. In the newly created 3D PCB, create a new 2D PCB and a new schematic
  3. Create a new 'electronics design' project and link the 2D PCB to the schematic
  4. Open my old Eagle schematic file in Fusion as a separate document, select the circuitry I would like to re-use, and copy and paste it into my new schematic file.
Unfortunately, this process only copies the schematic information and not the board layout. When I go to my new 2D PCB file, the footprints are all in the wrong place and all of the traces are gone.
I also tried copying the circuitry from the old board layout directly to the new 2D PCB, but it says "Can't backannotate this operation".
How can I copy parts of my old circuitry, including the layout and traces, into my new derived PCB?
2 REPLIES 2
yqliu
in reply to: jeremiahrose
1) Save your design as a new document and link your pcb to this new document.
2) In 3D PCB environment, don't create a new 2D PCB but link to the one created in step 1)
jeremiahrose
in reply to: yqliu
 That worked perfectly! Thanks!
