Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Copy device from one library to another
5 REPLIES 5
infinite.machinery
3026 Views, 5 Replies
In Eagle I could copy a device from one library to another from Control Panel. How do I do that in Fustion 360. I don't see any obvious workflow for doing this.
5 REPLIES 5
Hello @infinite.machinery,
I hope you're doing well. This is something we are working on, currently the only option is to copy/paste.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
voxpipes
in reply to: jorge_garcia2
Actually this IS possible. You can find the original post that uncovered this workflow here:
https://forums.autodesk.com/t5/fusion-360-electronics/workflow-for-creating-packages-in-f360-electro...
1.- Open the destination library.
2.-Add to your schematic/board the device you want to copy.
3.- Right button and "copy footprint device to library".
At least as of the latest version of fusion you can import parts when creating a new components, symbol, footprint, package. I did notice this option is only available when using the toolbar icons not when right clicking in the library manager.
This should streamline your workflow
robert1356
@jorge_garcia2 what do you mean by "copy/paste" in the comment about the only option.  I don't see a way to copy OR paste when I'm in the library editor.  If I want to use a footprint from another library, for example, I open the library with the footprint I want.  I select "Footprints" and select the footprint I want, there is no option to copy that footprint.
Ah - I just discovered the answer - you have to OPEN the footprint, use select to select ALL of the footprint, then you can go to edit->copy.  In the new library, you have to create a new, empty footprint, then edit->paste into that new drawing.
I hope this library editing is improved
"I hope this library editing is improved"👍
Autodesk, please make processes like library editing more intuitive.  The streamlining of common tasks is more important to me than new features.
