Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Copper Polygons are not separated from GND polygons
2 REPLIES 2
FrankEagle
135 Views, 2 Replies
Currently I cannot have copper polygons separated from GND plane.
Am I doing something wrong with the polygon properties?
2 REPLIES 2
Hi Frank, hope you are doing well.
It looks like these polygons are sharing the same "rank", could you adjust the rank in the polygon properties so that they are no longer the same. You can control the order in which they are poured with the values of the rank setting.
Hope that helps!
PJ
It helps a lot!
Many thanks PJ.
