Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Convert to Poly in Layout
2 REPLIES 2
wayneweeks
71 Views, 2 Replies
I have been watching the excellent tutorials for schematic and layout, trying to follow along. Question...when selecting a PCB outline from the dimension on layer 20 to copy for a ground or power plane, when I right click I don't see the 'Convert to polygon'. Not sure what I am doing wrong.
Thanks for the help.
2 REPLIES 2
jorge_garcia2
in reply to: wayneweeks
Hello @wayneweeks,
I hope you're doing well. Two things that could be going on. 1) The convert to polygon command does not work with circles. You can workaround it by using two arcs to make a circle. 2) The convert to polygon command can only work if you have a perfectly closed outline (no overlaps, no gaps). If you have an outline that is not a circle but still don't see the command make sure that the outline is perfectly closed. Often when this happens there is some small gap that you can't see so you have to use the inspector and check every segment of the outline to make sure all of the end points connect.
Let me know if you have any other questions or concerns.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
wayneweeks
in reply to: jorge_garcia2
Thank you Jorge. Yes, it was a circle, trying to be too clever for my own good 😀. I changed to a square for now and there's no problem. I'll go back and try with a couple of arcs at some point. Really appreciate the quick response.
