Connect mounting hole to ground plane
gixxerrider73
Message 1 of 8
gixxerrider73
I have a PCB that I drew including the two mounting holes.  How can I add pads around the holes and connect them to the ground plane?
attached is an example of what I want to do and my current PCB design.
Replies (7)
Message 2 of 8
yaqoubdesign
I was wondering the same thing.
Message 3 of 8
jorge_garcia
Hi @yaqoubdesign and @gixxerrider73,
I hope you're doing well. Easiest way to do this would be to use Vias that are connected to ground.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 4 of 8
gixxerrider73
@jorge_garcia wow! that was super easy.  I did not realize you can overrider the dimensions in the drop downs.  Thank you sir!
Message 5 of 8
roatchristopher
@jorge_garcia I'd like to do this with a mounting hole that is pushed back from the 3D design.  The hole was created by editing the linked PCB within my mechanical enclosure to get the correct position and diamater.  Is this possible?
Message 6 of 8
jorge_garcia
Hi @roatchristopher ,
I think in this scenario you have to place a plated through hole on the 2D PCB and then locate it precisely on the 3D PCB. The 3D PCB editing will only get you a normal plain hole it won't be plated or able to hold a signal.
Best Regards,
Jorge Garcia
Message 7 of 8
roatchristopher
Thanks for the idea.  I don't see how to place a plated through hole.  I can place a via (which technically is a plated through hole), but it is not movable from the mechanical edit-in-place editor.  It seems only true components can be moved.  Another hitch is how to set the diameter and drill size from the mechanical side.
I can work around this another way in my design, so it's not a show-stopper.  I'm not sure how many people this would affect, and so may not be a high priority.
Message 8 of 8
jorge_garcia
So I apologize, it seems I recommended you use a feature that hasn't been released yet. This will be released at some point in order to allow precisely the workflow you are looking for. For now the workaround is the best approach. You can make a plated through hole pad as a component and then you'll have the benefit of being able to place it precisely on the 3D component because it is technically a component.
Best Regards,
Jorge Garcia
