Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Config file location
7 REPLIES 7
Message 1 of 8
silvio3105
167 Views, 7 Replies
I cannot find config file. Checked "C:\Users\{USER}\AppData\Local\Autodesk\webdeploy\production\22651d53e422c0183a6147899471ab1dca9a3f80\Applications\Electron" and nothing.
Windows 10.
7 REPLIES 7
Message 2 of 8
jorge_garcia2
in reply to: silvio3105
Hi @silvio3105 ,
Did you try just doing a system search for eaglerc? Make sure it includes hidden files and folders.
This file is purposefully deep in the system because it's not meant to be edited directly, that's why it can be hard to find.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 8
jesper8W75R
in reply to: jorge_garcia2
@jorge_garcia2
Isn't it about time you move the rc stuff to the Preferences page?
It's 2022, not 1993.
Message 4 of 8
silvio3105
I found only config file from EAGLE 9.6.2 that I've used before switching to Fusion
Message 5 of 8
panpan_fan
Hi @silvio3105
I hope you are doing well!
There is one way that you can find the config file path.
In the text command, you can type 'pcb.path' and then press Enter.
You can find what you want.
Hope it can do some help.
Panpan Fan
Message 6 of 8
jesper8W75R
in reply to: panpan_fan
Thank you, @panpan_fan
Wow, this is SO modern and professional. Definitely extraordinary!
Very suitable for a user friendly, commercial program in 2022.
Message 7 of 8
silvio3105
in reply to: jesper8W75R
Can you please jump out of topics when you don't have anything useful to say? Thanks.
Message 8 of 8
silvio3105
I'm not sure where I have to type pcb.path.
EDIT: Found it. Thanks.
