Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
component update problem with file generated from circuit board
0 REPLIES 0
Message 1 of 1
franck.malepart
105 Views, 0 Replies
Currently I design an electronic circuit with the tool integrated to fusion 360. From that design a I generate a 3D model of my electronic circuit.
Currently, I have to test the integration of the electronics into a casing designed for us by a designer (step files).
To do this, I've created a file containing the parts (casing top, casing bottom and my elecronics) and I added the mecanicals constraints between them. Until now there is no problems.
I found an issue in my design and i have to change the routing of my PCB, I generate again the 3D model and the assembly file notify me that the 3D model have to be updated.
The problem is here : when i update the 3D model generated from the PCB, everything (pcb sise, holes, routes and silk) are updated except the components place (they stay where they were previously). I attached a screenshot of the file updated (we can see that the components are not updated with their new coordonates
0 REPLIES 0
