Announcements
Component changed results in error when generation/updating the 3D model
mihai.pauciuc
Observer
mihai.pauciuc
Observer
Observer
I am fairly new to the Fusion360 product in general but also to the electronics design part.
Now I am facing a problem that I can not find a solution for browsing the forums.
I have update a component design in my project with this library https://componentsearchengine.com/part-view/EC12PLRGSVDF/TOP%20UP . I have used the library contained in the folder named "eagle" .
Placing the part in schematic and then moving it in the actual 2D PCB board design goes perfectly but when I try to push the modifications to 3D I get the following errors :
Now this foot print / symbol has no 3D part attached to it if that helps and if I revert the design to an older version and I keep the new part outside the pcb there is no problem as long as the part is not on the pcb it shows outside of the floating.
I have tried to download the same foot print from a different website ( https://www.ultralibrarian.com/ ) but I got the same behaviour / error though that time I have also attached the 3D component to the design .
Can please someone give me hint what I am doing wrong ?
Generating the 3D body of my board is probably one of the most valuable features for me in fusion360 electronics so I am truly looking for a way to sort this out 🙂 .
Best Regards,
Mike
Replies (0)
