Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Complex polygon cutout not processed correctly with vias on route 2
2 REPLIES 2
lodderj
165 Views, 2 Replies
It looks like I stumbled on a bug regarding complex Polygon Cutouts with more than 4 points on Route 2.
Some of the ground vias are not connecting when they are inside an "peninsula" of the complex cutout.
Example: see the single via on the lower capacitor and the bottom left of the 4 separate.
This strangly only applies to layer 2 Route2.
Fusion 360
2.0.11894
Active Plan: Fusion 360, Subscription
Windows 10 Pro 21H1 x86_64 (19043.1526)
2 REPLIES 2
jorge_garcia2
in reply to: lodderj
Hi @lodderj ,
I hope you're doing well. Thank you for this example, I know some fixes were done for polygons. I'm not sure if they are in the next release.
I'll try to test your files to see if it's been addressed.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
j.lodder
I checked this again today, looks like this is no longer a problem in 2.0.12665 👍
