Command line help
pblase
Command line help
pblase
If Autodesk is going to insist on retaining the command-line for Fusion 360 Electronics, could you at least put in a help feature? Nowhere that I can find are all of the various commands documented. Even in the original UNIX CLI, I could type "command ?" and get the help page for that command. Just typing "?" gives a list of all commands. Please consider adding this, it would help greatly.
jorge_garcia
Hi @pblase,
I'll put in a request for this, at the minimum it should just take you to this page.
https://help.autodesk.com/view/fusion360/ENU/?guid=ECD-CLI
This page contains all of the reference information for all of the command line options.
I'll put in a request for this.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
jd.vorheis
Correct URL for the command reference for Fusion Electronics: https://help.autodesk.com/view/fusion360/ENU/?guid=XXX-ECD-CLI
HelenChen-ElectronicsQA
Hi @pblase ,
Hope all is well.
Much appreciated for reporting this issue to us ago.
Good news that we have put a fix about it in the latest Fusion build 2.0.19725 which was live yesterday.
Now if you type command in CLI like "help route", after pressing Enter key to run the CLI, then you will get the online help about the Route CLI command directly.
You could get other CLI commands online help doc there too.
Could you please upgrade to the latest version to have a check? Hope it helps.
Please feel free to let us know if you need further assistant.
Thank you.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
