Closing small gaps in poured ground layer
ilia.vitsnudel
ilia.vitsnudel
Hello, I would like to close small gaps that have been left after Polygon pouring for the ground layer or make some small additions to improve the shape. I have tried to reuse Polygon pour command, but it seems to generate an empty dashed polygon that doesn't seem to add an additional ground.
I am attaching an example of what I would like to achieve.
Thank you,
Ilia Vitsnudel
Replies (30)
Hi Constantin,
I have added the ObjectType = Wire condition to Object 2, but it still
didn't work.
Then I tried to temporarily remove the wire that is coming to the pad and
then I was able to widen the arc and get appropriate Anti-pad size (i.e.
the gap between the pad and the surrounding ground).
So I added another design rule to try to resolve the problem with an
incoming signal. It looks like this:
Object 1:
Object Type = Wire
In Signal = N$A1_S3 (incoming wire)
Object 2:
Object Type = Wire
In Signal = DGND (added arc - wide wire)
But this didn't help.
Do you have a method to print-out why the property change failed?
Thank you,
Ilia
Hi @ilia.vitsnudel Ilia,
I can't see any problem with the rule scopes you have added. The only question is if any of the wires is supposed to be part of the copper pour outline because that would not work because the copper pours are not checked by DRC because they are DRCed when they are poured. So for the Object 1 / Object 2 scopes do you expect any of the 2 wires to be part of the copper pour outline or these are just wires that you have routed? Also I asume that the copper clearance value you have for this rule is bigger than the general wire-wire rule.
Can you please send some snapshots if possible or a movie if that's not too much to ask?
Thanks a lot.
Kind Regards,
Constantin Popescu
Principal Software Engineer
Hi Constantin.
May be we can have a short Zoom session?
I am located in Israel, so any reasonable time will work for me.
Thank you,
Ilia
Would tomorrow 15/01/2025 8:00 AM Tel Aviv time be good for you? If so can you please send me a Zoom meeting invite to constantin.popescu@autodesk.com?
Kind Regards,
Constantin Popescu
I forgot to mention that I am located in Sydney, Australia and we are 9 hours ahead of Tel Aviv.
Kind regards,
Constantin Popescu
Thanks, can we do it at 7AM or 9AM Tel Aviv time?
7:00 AM soungs great. See you tomorrow.
Kind Regards,
Constantin Popescu
What is your e-mail address, so I can issue a Zoom invite?
jorge_garcia
Hi @ilia.vitsnudel ,
I hope you're doing well. Constantin's email is up a few posts in this thread.
I'm sure you saw it but just want to make sure.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
My email address is constantin.popescu@autodesk.com
See you later.
Kind Regards,
Constantin Popescu
chuck_toddN7PTC
Hello @ilia.vitsnudel,
Can you post a screenshot of the final custom clearance rules and layout to show the end results?
Thank you.
BR - Chuck
