Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Circuit Board Template
2 REPLIES 2
charlessXNBDU
179 Views, 2 Replies
Is there a means to create a template for circuit boards in Fusion360 electronics? We need to design to a defined board size, with defined NPT holes, and mechanicals (connects, etc.) aligned to a defined specification. Best we can find is copy and paste, thus far.
2 REPLIES 2
Hi @charlessXNBDU ,
I hope this message finds you well. There's a few ways to do this, if you need a consistent board shape with basic mechanicals. The easiest way to do it is to save a sch/brd design with the minimum configuration.
Once you have it then when you make a new design you can link to the minimum config sch and board as copies and work from there.
Pretty straightforward.
Let me know if you have any questions.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thanks. I decided to use that process to create baseboards. It works. It is not as smooth a process where I have an existing schematic and board I want to resize to a standard baseboard.
