Announcements
Cant zoom
bora2002md
Message 1 of 8
Cant zoom
bora2002md
My mouse works perfect when other workspaces like cad, cam, sheet but in electronics i can't zoom with my mouse it goes up and down when i use my scroll wheel.
My mouse is mx master 3 and i am on 16" MacBook Pro (MacOS 10.15.7).
Replies (7)
Message 2 of 8
yqliu
Hi @bora2002md ,
I don't have a mx master 3 to confirm the issue at this moment. But we will look at it.
Richard
Message 3 of 8
bora2002md
I tried with different mouse (Logitech G300) and it works fine. Maybe its about Logitech options app? But i will be very happy if Autodesk devs can fix it. Another weird think i found I can't pan infinite with trackpad it limits me to the component area.
Message 4 of 8
RichardHammerl
Hi @bora2002md
could you please check the Preferences for Electronics (click you profile icon, then Preferences)?
What is the setting for legacy mouse wheel mode and what if you change it?
Hope this helps.
Richard Hammerl
Message 5 of 8
bora2002md
It was unchecked checked it and now works perfectly fine thanks!
Message 6 of 8
m_walczak
I know it is a little late, but if you still want to use the vertical pan capability, turn off the legacy mouse support. Now you have the vertical pan.  To Zoom in and out just press the vertical scroll wheel down while scrolling.  No you have everything as it  should be.
Message 7 of 8
JetForMe
This does not work for me using an Apple Mighty Mouse (the one with the 2D scroll ball). If legacy is turned off, it just pans, which I want. But clicking and scrolling does not zoom. I'd sure like to be able to just hold a meta key while scrolling to zoom.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
Message 8 of 8
ZMOSCA
Community Visitor
Community Visitor
life saver!
