Announcements
Cant't remove appearance/material from 3d PCB
bastian.jaeger
bastian.jaeger
I created a PCB with Fusion 360 and generated the 3d PCB to it.
By accident I added a white paint material to it (not sure to what all parts/bodiies/components of it).
My first thought was to simply delete the 3d PCB and let Fusion generate a new/fresh one, but apparently deleting is not allowed.
Quesion: How can I remove all appearance(s) or any other stuff from the 3d PCB to only get the "fresh" 3d PCB that Fusion would create?
Thanks!
RichardHammerl
Hi @bastian.jaeger
thank you for your participation in our Fusion Electronics forum.
In the image, I attached Nickel to the 5 pin connectors. With a right-click onto the Nickel material icon in the APPEARANCE window a context menu opens. Select Unassign and delete.
I hope this helps.
Richard Hammerl
bastian.jaeger
Hi Richard,
yes, this helps. But only kinda.
If I am not sure what components or what materials I have changed, it there a overall solution to it?
