Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
cant move any foot print in pcb layout now
2 REPLIES 2
32loyal
193 Views, 2 Replies
so no cross hairs show up so i can move/select the footprint just randomly happened turned all layers visible still no cross hairs any thoughts?Eagle 9.6.2
Labels (1)
2 REPLIES 2
jorge_garcia2
in reply to: 32loyal
Hi @32loyal,
I hope you're doing well. Double check the selection filter, make sure to reset in case you had adjusted it to help you make a complex selection.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
32loyal
in reply to: jorge_garcia2
Everything is configured properly in eagle i found if i restart eagle i get a 50/50 chance of origins layers working so if it does loose the origins layer i usually only have to restart eagle maybe around 5 times on average.
