Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Cannot get any latest files.
1 REPLY 1
shaische222
103 Views, 1 Reply
I was working today and everything was fine but then all of a sudden I can't get latest on a sub-assembly sheet metal part and an eagle file that was pushed. I thought maybe my sub-assembly part got corrupt so I re-made the part and same issue. Then I checked my other assembly designs to see if it's a fusion issue or something, same problem. All across the program I can't get latest version.
I did a clean uninstall of Fusion 360 (btw your clean uninstall no longer works for latest Mac versions) so I had to do it manually.
Restarted my computer, issue persists. I'm out of ideas and I need to get this working. Any help appreciated.
I also get an error now when pushing a design from Eagle to Fusion that worked fine for months. See attached picture. Don't know if it's related. Push worked for a while even with the error, but then it just completely stopped pushing it and kept saying "Error pushing".
1 REPLY 1
jorge_garcia2
in reply to: shaische222
Hi @shaische222 ,
Did you place the sheet metal part into the PCB in Fusion? If you did that's probably the problem. The PCB file in Fusion should only ever contain the PCB if you add anything else it could break the ability for the files to sync.
Let me know if that's what you've done or if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
