Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Cannot change color
1 REPLY 1
buchaki
142 Views, 1 Reply
Cannot change color
Hi, I downloaded the .igs file and found out that I CAN change some colors and some not (it stays orange/yellow). I would like to have everything black. Does anyone know how to fix it?
Tags (1)
1 REPLY 1
ritste20
in reply to: buchaki
The igs file imported as surface bodies. The entire model is individual surfaces and not "watertight". Perform a stitch operation on the top and bottom halves of the case and you should be able to apply appearances to your model once it is a solid body.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
