Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Can we use EAGLE (licensed) to edit Fusion 360 Electronics projects?
1 REPLY 1
sehaque
101 Views, 1 Reply
I can easily use Eagle, and now am trying to use Fusion 360 Electronics but finding the embedded eagle system a bit raw, and difficult for now as some of the commands still have to be entered as CLI where no icon exists. That said, there are some things that are more intuitive in standard Eagle. Well, is there a process to start a design from Fusion 360 Electronics, after Fusion 360 MCAD, and then shift back to Eagle (the application) ? Eagle opens up local files easily, but can it open up Fusion 360 Electronics files and if I do the edits, will there be a merging of the two versions?
1 REPLY 1
jorge_garcia2
in reply to: sehaque
Hi @sehaque ,
I hope you're doing well. You can export the designs from Fusion 360 into a format that EAGLE can understand and work on the files from there. These files will not automatically sync back to whatever you have in Fusion 360 so you would have to upload it to Fusion again if you want to work with it in Fusion 360 Electronics.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
