can we set pad size in length x width format
anuradha.bodke
anuradha.bodke
Hello Team,
as long time goes Please add drill drawing chart in pcb  it is  very important
also in pcb library editor for long hole please add flexibility of pad dimension , it is very useful while using
slotted  long pads, other pcb layout software have this facility ( pad size in L X W format)
Anuradha
yqliu
Thanks @anuradha.bodke for your suggestion. We will definitely consider and prioritize this.
anuradha.bodke
Hello Team ,
Many Updates are release for fusion electronics,
1) but as I told earlier drill drawing chart was not prepare in fusion electronic pcb editor till date
and in Eagle it was done
Please add all the feature of Eagle in fusion electronics
2) flexibility to change pad size of through hole in LXW  format ( as we change smd pads in LXW format)
now pad size changes only in diameter , this feature was very much helpful for
Thanks in Advance
Anuradha
attached image for  drill drawing chart
anuradha.bodke
Hello Team,
please check below and update on it
Thanks and Regards
Anuradha
