Can't import Arduino Nano schematics
nmingotti
nmingotti
Hi, I am a customer of yours since several years, I am very new to Fusion360 for electronics though.
I wish to try it out, but the first thing to have for my use is the possibility to load Arduino Nano into my circuit as a component.
I have tried several times with all i could find on the internet, nothing works.
For example, when i try to load the sch file found  here it fails saying there is some error in line number XXXX. I can't read it because the window with the error faded away (please correct that, if there is an error, i must be able to copy past the error and the window should not close before i read it all). If you can please check it out, i am sure i am not the only one using Arduino Nano. Bye !
yqliu
Hi @nmingotti , the problem is the file contains some special characters. Actually the page from which you downloaded the files has provided the solution (just don't save as rpt but save as sch/brd):
