I'm using v 2.0.13377 on MacOS 12.4, I can't cancel route command if started from a via.
To replicate the problem you need a trace terminated on a via and an unrouted trace starting from the via:
select R route command
click on the via
press ESC to cancel the operation, it does't exit route command.
Regards
