Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Can't delte junk files.
6 REPLIES 6
zigzag2015
136 Views, 6 Replies
HI, I have asked this question before....I need a methhod to delet junk files.
At the current time the biggest folder in my account is the Trash folder because I can't delete anything out
of it.
As an example I, a few minutes ago, I broke the link to a PCB in the Electronics Design folder that I might
make a new PCB. Depsite the link being formally broken I cannot delete the file by virtue of a link???
I swept it to the Trash Folder....yet another one.
Would someone please devise a means of either breaking or indentifying the links to other files.
This is really starting to piss me off....I can't control my own work.
Craig
6 REPLIES 6
PinRudolf
in reply to: zigzag2015
Have you checked the version details in the Data Panel? It should give you tabs like "Uses" and "Used In" to show what files it has been linked with.
zigzag2015
in reply to: PinRudolf
Yes, I have multiple times.
I have a file called BLDC1, a PCB file, in my Trash folder. I have inspected its 'uses'....it has none. Likewise, I have inspected
it's 'Used In' and it not used in any other file. When I try to delete it however Fusion refuses on the basis that its used in other designs.
Give me a break......I just checked it......
Craig
jroddisRT8HL
This is pretty annoying you're right, I'm also using a 'Trash folder'. Of the files in there, I seem to have two that are linked to each other.. somehow, and I can't delete either because it's dependant on the other. I also can't seem to find a way to break the link, so now I've got a growing trash folder..
I wonder how much space is taken up on F360's servers with trash.
jorge_garcia2
Hi @zigzag2015,
I hear you, even if a file isn't used in any other design once it's been saved a few times and has a few revisions, these revisions reference each other internally. That's the reason it won't let you delete the file even if it's not referenced by anything else.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
zigzag2015
in reply to: jorge_garcia2
Hi, yes that is a fair description of what's happening.....what I want is a solution to fix it.
Craig
jorge_garcia2
Hi @zigzag2015 ,
If I had a solution for it, you would have it already. This is something endemic to Fusion's cloud structure and as far as I know there is no way around it currently.
Wish I had better news.
Best Regards,
Jorge Garcia
