Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Can't create square pcb, only spline shaped pcb's.
7 REPLIES 7
Message 1 of 8
FloridaJo
271 Views, 7 Replies
Coming from Eagle, I just want to create a pcb without designing a circuit first.
I can use Board Shape > Outline Spline, but Board Shape >Outline Polyline does nothing.
I just want to dimension the pcb and am stuck there at step one.
Any help would be appreciated. thanks.
No youtube videos on this simple step either.
Tags (2)
Labels (1)
7 REPLIES 7
Message 2 of 8
panpan_fan
in reply to: FloridaJo
Hi @FloridaJo
I hope you are doing well!
I am not sure if you want to create an empty PCB. If this is your question, you can follow the steps:
1. New Electronic Design
2. New Schematic
3. Switch to PCB Document.
Then an empty PCB will shows up.
And I also try the Outline Polygon command, it also works well for me.
You can see my video here https://autode.sk/2TahMCP
If I misunderstand something here, please leave your comment, thanks!
Panpan Fan
Message 3 of 8
FloridaJo
in reply to: panpan_fan
Thanks for the video.
I can't do that in mine.
I'm on a mac if that make any difference.
Here is a screentcast video:
https://youtu.be/qqgkI_oieWU
Message 4 of 8
manuel.sobral7
At 00:30, you click "ok" button. When you do it you deactivate the function.
I think it's just that.
Message 5 of 8
FloridaJo
in reply to: manuel.sobral7
Wow! Talk about unintuitive.  One would think okay it want's me to select these options, then I hit okay and draw.
Thanks That was driving me batty.
Message 6 of 8
panpan_fan
Hi @FloridaJo
As @manuel.sobral7  mentions, you need to keep the command dialog open when you want to run the command.
The rule is for all commands which have command dialog in Fusion 360.
Besides, I hope you have seen playlist here https://www.youtube.com/playlist?list=PLmA_xUT-8UlI0k9YsKK23onh_0VV2_DP5
We will continue to post videos to demo or introduce Fusion Electronic. You can have a look if you want to learn more about Fusion 360 Electronic.
If you have any other problems, please leave your comment, thanks!
Reegards,
Panpan Fan
Message 7 of 8
FloridaJo
I think in Fusion360 design it appears more like a context panel.
In Electronics Design it appears more to be a Modal box which begs to be closed before an operation.
Just my 2 cents.
Thanks for the link.
Message 8 of 8
panpan_fan
Hi @FloridaJo
Thanks for your comment.
Do you mind describing more details about the feelings of Electronic command dialog?
What makes you think that the  a Modal box should be closed before an operation?
And I will give your feedback to our develop team to see if we can do some improvement here.
Thanks!
Ragards ,
Panpan Fan
