Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Can't create a 3D PCB from 2D
3 REPLIES 3
mad.macs
134 Views, 3 Replies
Screenshot 2023-08-27 at 8.53.09 PM.pngI have a 2D schematic, and a 2D board designed and ready to push to a 3d board, but I don't see an option to create a new 3D board. The only option I have is to Push to 3D board. Nothing happens when I do that. These boards were previously linked to other 3D boards, but I just want to create a new 3D board based on the 2D drawing. ( I was getting unresolvable 2D/3D out of sync errors)
3 REPLIES 3
mad.macs
in reply to: mad.macs
I have PCBS I can't delete as well. I would suggest that in addition to warning you that a file is referenced in another document that it tell you what other files it is linked to. Better yet, there should be a way to nuke the links and sever ties.
Putting the files in a folder,and deleting the folder doesn't work for this case either.
yqliu
@mad.macs , please check if the 3D PCB command dialog was docked somewhere on the side panels.
mad.macs
I see what you mean. It's likely the button was below the dock, it's iina n odd spot. You click on a button labeled "Push to 3D PCB" and you expect it to do it. I'm not sure why it takes 2 clicks to accomplish the push. The settings for the push probably don't get changed often, and it seems an unnecessary step.
