Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Can't add new attribute
2 REPLIES 2
raytongjob
116 Views, 2 Replies
I try to add new attribute the a device variant. I can't add a name with auto suggestion. For example, I want to add tolerance , when I type 'T' ,the field will auto suggest 'THERMALLOSS', the  'OK' button become disabled. I then delete the name field , 'OK' button remain disabled. I tried other names,  names without auto suggestions are ok to add, but not with auto suggestions.
2 REPLIES 2
panpan_fan
in reply to: raytongjob
Hi @raytongjob
I hope you are doing well!
It is a known issue (Post in https://forums.autodesk.com/t5/fusion-360-electronics/electronics-library-component-attributes-weird... has been reported to the develop team.
If you still want to use 'T' or 'M' as initial of attribute, you can create the attribute with other initial letter and then Change the Attribute name. It can be a workaround.
Sorry again for all inconvenience. I will keep you updated when we fix this issue.
Panpan Fan
panpan_fan
Hi @raytongjob
Today we release Fusion 360 V2.0.15775 and this issue has been fixed now.
Please update Fusion 360 and have a try, thanks!
Panpan Fan
