Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Can 3D model be used by multiple footprints?
2 REPLIES 2
TimPaterson
66 Views, 2 Replies
I have two slightly different footprints for the same device (a USB-C connector). I created a 3D model for one of the footprints, and want it to be used by both.  The only options I see are "Create New 3D Model" (which I used for the first one) and "Attach Copy of Existing 3D Model".  If I select the latter, it prompts me to save the 3D model under another name (I didn't proceed).  Is there a way just to share the same model?
2 REPLIES 2
Taylor.Chris
in reply to: TimPaterson
Sadly, right now the answer is no.  You will need to create two packages.  You can xref your 3D model into both packages so that the geometry is shared, but this still results in 3 assets in your data panel.
This is something we are actively working on improving now.
TimPaterson
OK, so I made a new model, and dropped the existing model into it.  That's seems to have worked, creating a link to the original, and giving me two assets instead of three.
Or maybe not.  When I exited Fusion, it prompted me to save it again, and created a third asset.
