Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Bundled Library JSON can not be loaded
11 REPLIES 11
Message 1 of 12
VertigoMFG
1166 Views, 11 Replies
Ok so here is an interesting one, just taking the tome to setup the electronics workspace in Fusion and I have this error any ideas? this is a clean install of Fusion which I had to do to fix another issue today.Capture.PNG
11 REPLIES 11
Message 2 of 12
SallyYang
in reply to: VertigoMFG
Thanks for your feedback.
The issue has been reported to our development team and the DID is FUS-59613 .
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 3 of 12
andrewXEL68
in reply to: SallyYang
Has this been fixed or is there a work around?
Message 4 of 12
SallyYang
in reply to: andrewXEL68
Sorry, it's not fixed yet.
You can browse to your libraries and select to get them in used.
Sally
Sally Yang
Autodesk, Inc.
Message 5 of 12
deanforbes
is there an update to this
I am also experiencing this error
Message 6 of 12
SallyYang
in reply to: deanforbes
Sorry, this issue hasn't been resolved yet.  Please browser to the libraries to get them in use.
Sally
Sally Yang
Autodesk, Inc.
Message 7 of 12
I know it isn't fixed but is there a workaround?
Message 8 of 12
Please refer to the workaround in https://forums.autodesk.com/t5/fusion-360-electronics/issue-downloading-bundled-libraries/m-p/967376....
Sally
Sally Yang
Autodesk, Inc.
Message 9 of 12
Peteroh274
Hi I hope all are in goof form! I am new to the Electronics element of Fusion and have the same issue. I am keen to move forward in designing the control system for our F24 Race car  Can someone please help in suggesting how I can find the schematic, 3D and pcb layout library for my components. Sorry to be vague and appearing so inadequate
Peter
Message 10 of 12
SallyYang
in reply to: Peteroh274
Hi @Peteroh274 ,
Thanks for your interest in trying electronics in Fusion 360.  It's hard to tell you how to find the elements you requested with a simple word, but we have some learning stuff that may help you to start your electronics project:
Hope you will enjoy designing in Fusion 360 electronics.
Sally
Sally Yang
Autodesk, Inc.
Message 11 of 12
Peteroh274
Hi Sally
Many thanks for the speedy reply – I shall be looking at the resources you suggest and engage with the learning pathways offered.
To help can you point me to the resource that helps me load/locate the available Libraries as I continue to get the error message Bundled JSON can not be loaded.
Best wishes
Message 12 of 12
SallyYang
Sure, there is a workaround mentioned in my previous reply.
You can get it from https://forums.autodesk.com/t5/fusion-360-electronics/issue-downloading-bundled-libraries/m-p/967376...
But as a quick workaround you could sort the Available libraries list by Managed Folders and select all libraries that come from "Eagle Pcb" in the list (Shift + left click). Now click the Use button. All "bundled libraries" that would come with EAGLE are usable now.
The same works with all libraries that are in the Fusion Electronics Managed Folder. Theses are the libraries that come with Fusion Electronics.
Sally
Sally Yang
Autodesk, Inc.
Tags (1)
