Bugs
Bugs
Hi guys,
New version with included "Eagle" is very unstable on my computer. Every few minutes crashed, undo and redo don't work on schemat and board (it is really bed when you can not undo changes).
Unfortunately after crash schema has new version but board not and I have a lot of warnings with "Bird and schematic are not consistent".
Do you have similar experience? I'm working on MacBook.
I have to wait for next stable version.
Replies (7)
Spragnut
I'm getting similar issues, although my crashes are pretty consistent and mostly when exiting Fusion.
I've tried manually saving and leaving Fusion open long enough to fully sync but it doesn't seem to help.
To give an example, in the current project I'm working on I had a schematic laid out and approx 80% of a board complete. The latest change to the schematic consisted of adding some net classes and an additional connector. I saved after making these changes and worked on the PCB, when I had to leave I saved everything and left Fusion open for an additional 10 minutes before closing - it crashed whilst doing so (I have logged 3 or 4 of these crashes today). I've just reopened the project and the net classes and additional connector haven't been saved in the schematic, meaning consistency is broken because they both exist in the PCB.
kb9ydn
For undo/redo, the normal hotkeys don't work yet.  You can use the arrows on the quick access bar towards the bottom of the screen.
C|
What do you mean?
I can not find any quick access bar in the electronic section.
kb9ydn
This is on a Windows machine.  On a Mac it may be different.
C|
Ohhh yes. stupid me. I have to change my glasses to stronger one 😉
On Mac is exactly the same.
Thanks a lot
kb9ydn
I missed it too at first.  😔
C|
rbkyorem
Yeah i have been getting a lot of crashes too, yet still trying to finish a basic project to see what is here and what is not, what is working what is not. I found some other bugs, missing functions myself.
  • Can't draw frame (We could in Eagle or maybe I could not find how to).
  • Can't import parts from other libraries. (Maybe I could not find how).
  • Labels does not pop up a option bar to change xref.
  • Can not convert board outlines to polygon by right click nor polygon from outline works.
  • Libraries conflict with same names. I had created Transistor library on my desktop, today at work I wanted to continue on the project but saw that instead of my own Transistor library Fusion tried to use it's own. Making it hard to update parts from library.
  • Can not use _EXTERNAL_ attribute for parts without footprints.
  • Crashes usually resulting in consistency errors.
