Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Bug with component rotation
4 REPLIES 4
silvio3105
125 Views, 4 Replies
there's a bug with rotating component in 2D PCB.
Look at designator. After first rotate, I did CTRL + Z and tried again.
Thanks!
https://youtu.be/WsGhKotcZjY
4 REPLIES 4
silvio3105
in reply to: silvio3105
Bump!
yiqiu.han
Hi, @silvio3105
You mean the rotation angle of silkscreen "R1" is not correct at first, right? Could you please share your board file with us for investigation?
-Yiqiu
silvio3105
in reply to: yiqiu.han
Yes.
Can you try with generic component? I had same issue with both THT and SMT component.
On first try, designator angle will be some garbage, then Ctrl+Z and reenter component's value and then it will work.
It does not look like file/project related problem.
silvio3105
Little bump
